 GQ-4X burn 27C4002
CAP
Paraguay
Posted - 09/19/2008 :  16:16:19  Show Profile  Reply with Quote
Hi.. I have a new True USB Programmer GQ-4X RE 1.10, and ADP-054 16 Bit EPROM 40/42 pin ZIF adapter V3 for Willem (jumper j1, short 1 ?2)
And I work with GQ USB 3.02BETA, I TRAY TO program a M27C4002 AND SHOW, WRITE FAILED, ADDRESS00X000000, BUFFER=0X54 DEVICE =0X00
If I push “GET id?show, function not supported on this device. Is correct?
I chek whith 27c256, 27c64, sst39sf020, and is right. (whihout 16 Bit EPROM 40/42 pin ZIF adapter )
In the adapter there are free j2,
It has attached a power 9v,
Can you help me??
Thanks.
Posted - 09/21/2008 :  14:53:52  Show Profile  Reply with Quote
It seems your EPROM chip is not blank. You have to erase the EPROM before write anything.
On GQ-4X, J2 is not used. For this chip, the J1 need to set jumper on pin 1-2(short the 1,2).
CAP
Paraguay
Posted - 09/21/2008 :  19:40:48  Show Profile  Reply with Quote
!!!I SOLVE A PROBLEM.!!!
Thanks for your help.
CAP
Paraguay
Posted - 09/24/2008 :  10:44:51  Show Profile  Reply with Quote
Hello, me again. Clear with M27c4002 the UV lamp and then recording perfectly.
With 2 times I did the same memory.
Now attempt to write and give me the same write error But.
1) if there is a blank chek sometimes show "Chip is blank"
Other times, chek blank failed and it is 00, and on 08
2) if one reads the report gives FF, but when trying to write it gives write failed adress00000, buffer device 00 ff
3) sometimes reads and gives ff, in the editing screen, said device 0x00, attempting to burn.
The memories were erased 10, 12.15 minutes with a UV lamp G8T5,
The 2 memories are new. M27c4002 mark ST.
Reading the data sheet of M27c4002 found:
The M27C4002 is in the programming
VPP mode when input is at 12.75V, G is
HIV and E is at Pulsed to VIL. The data to be programmed
is applied to 16 bits in parallel to the data
output pins. The levels required for the address
and data inputs are TTL. VCC is to be specified
6.25V ± 0.25V.
The GQ-4X vcc rises Vcc to 6.25V?
It will not be that the lack tion for this program, since according to the list of the component is White 5.5V Vcc.
If I can help with this problem.
Thank you.
Posted - 09/24/2008 :  14:16:13  Show Profile  Reply with Quote
The chip need to be fully erased before write. Also, a blank check is needed to make sure the chip is blank.
Yes. you can use WVCC="6.2V". The "5.5V" only for the safty/compatibility reason.
Confirm the pin contacting before write.
CAP
Paraguay
Posted - 10/04/2008 :  09:02:26  Show Profile  Reply with Quote
Hello:
I can burn the M27C4002.
for the moment I can not get a blank EPROM, and I encourage you to get a taped another team for this if I broke the recorder and erase any bit.
Most likely the problem in this adapter, and you 40p the 16-bit version I have is V3.0
someone has a diagram of this accessory?
as I can get?
if any can give the link.
Thank you
Posted - 10/04/2008 :  13:20:28  Show Profile  Reply with Quote
What is the exact error message you got? If it can not pass the blank check, is it always at the same address? or random data.
Do you have second EPROM for testing? The EPROM has limited erase time. If the chip long time expose to UV light, then it may be demaged.
Here is schematic.
16BitEPROM_sch.pdf
36.15 KB
CAP
Paraguay
Posted - 10/06/2008 :  17:06:41  Show Profile  Reply with Quote
Hi.me again.
This is the one who always shows.
• What is the exact error message you got?
• This is the one who always shows.
80.95 KB
• If it can not pass the blank check,
• Always pass the "blank check"
• it is always at the same address?
• Yes, it is always in the same direction, and with either 27c4002, new,
• Do you have second EPROM for testing?
• Yes, I have purchased two new mouse.
• The EPROM has limited erase time.
• It was erased about 6 times in total, in cycles of 10 minutes, 20 minutes,
• The other will delete two or three times. With either of the two has the same problem.
• If the chip long time expose to UV light, then it may be Demag.
• never gave more than 20minutos,
• how many times you can erase?
• You can record, erase or immediately despeus have to wait a little while?
• Try to 6.32volts of vcc during recording. And not recorded.
• Once recorded, when METI tips oscilloscope and the tester pin 2 E, and VCC. With the buffer filled 2F And I interrupted, to see whether, if read. The eprom maintains the data.
• Check each of the seams in the zone, and pins that connect to the programmer. Anything that looks this good.
• In reading the pins A1-A17 give signals of direction, recording, I can not see, because it is interrupted in the first direction.
• In recording VCC changes from 4.35 to 5.5, and 6.32 on the way to more tension.
• E has no positive pulses.
• Vpp stabilizes 12.99volts
• Vcc has no noise or fluctuations during the recording.
I do not see that happening. In total burn 3 times since he purchased in programmer.
Posted - 10/07/2008 :  16:24:34  Show Profile  Reply with Quote
Do you have any other EPROM does not need the adapter?
That is to confirm the programmer is in good condition.
CAP
Paraguay
Posted - 10/08/2008 :  12:05:03  Show Profile  Reply with Quote
ZLM hello.
check the forum yesterday and had a response, with the addition of two lines which say 27c2400 test 1; 27c2400 and another test today when I go to the test disappeared! What happened? , Yet I could not do the test but now I do not have the text must be added to the file "devices.txt" can be put back? yet I could not DO THE TEST.
Today EPROM buy another 15 days to arrive in the U.S., mintras so I can only try to have. programdor go to the well with nmc27c 64q; am27256. I dont have memories of 16bit for testing.
thanks
Posted - 10/08/2008 :  14:01:22  Show Profile  Reply with Quote
Sorry, those two lines not correct and I removed those.
I should let you use this line:
Name="M27C4002(Test)",ID="XXXX",Class="27C040",Category="EPROM",MFG="ST",CodeSize="524288",Adapter="16 BIT EPROM Adapter 40pin/combo";
Select M27C4002(Test) when write the chip.
CAP
Paraguay
Posted - 10/10/2008 :  10:01:34  Show Profile  Reply with Quote
hi. ZML. me again
I did the test with the line: Name = "M27C4002 (Test)," ID = "XXX", Class = "27C040" Category = "EPROM" MFG = "ST", CodeSize = "524288", Adapter = 16 BIT EPROM Adapter 40pin/combo ";
and not burn. produces the same error, I confirmed that reads the memory, I put a eprom similar to the program in Spanish. and read some texts in Spanish. but I can not erase EPROM that this is my original, and I do not have the security of being able to record it again.
M27C4002 already bought another, but it is in transit. if you got to do another test. wait to get the new Eprom. and then you il.
thanks.
121.95 KB
Posted - 10/10/2008 :  14:20:14  Show Profile  Reply with Quote
I think something wrong with either your EPROM chip or adapter. Please wait for your new test chip. If it still does not work, then contact support@mcumall.com for the further assistance.
