 USB Programmer FUSE setting Abbrev?
brentfinley
Posted - 10/21/2008 :  13:59:11  Show Profile
Can anyone shed some light on the fuse configuration Abbreviations?
I am programming a 16F628 and some of the names are confusing.
Like in the Oscillator section.
HS - self explanatory.
many follow standard names, but the 2 modes of internal oscillator naming seem cryptic.
is there a list of exactly what they are?
Also.. is there a way to get the programmer to read in the configuration file written by the proton Pic Basic Pro compiler?
They write out a config file for the fuses. Can it be refreshed with the programmer Refresh button that does the code to?
Thanks,
Brent
Posted - 10/22/2008 :  10:30:12  Show Profile
For the fuse information, you can find it from the chip datasheet. The datasheet you can find from: http://ww1.microchip.com/downloads/en/DeviceDoc/40044F.pdf
If your PIC Basic Pro compiler generate standard Hex file and it with configuration information, then the software us able to read it.
brentfinley
Posted - 10/27/2008 :  12:06:18  Show Profile
Can your programmer be run in command line mode? This way it could integrate with the proton IDE: http://www.picbasic.org/proton_development_suite.php
They have a configurable command line generator that can call your program with parameters (no gui) to push the code directly to the chip.
Does your software work with this?
Posted - 10/28/2008 :  22:05:03  Show Profile
No. This programmer only supports Windows GUI interface.
brentfinley
Posted - 10/29/2008 :  12:05:08  Show Profile
What would it take to make it command line operational? It would be good for business if you can get a major IDE to integrate with your programmer.
