 GQ-4X MX29LV008CTTC-70G
sylverster16v
Germany
Posted - 12/02/2008 :  14:53:57  Show Profile  Reply with Quote
hi,
i have the GQ-4x and TSOP 20mm Adapter Complete Set.
Which adapter should i use and what and where should
i write in the devices.txt?
Posted - 12/02/2008 :  22:51:15  Show Profile  Reply with Quote
Adapter="TSOP40A"
Try this line:
Name="MX29LV008T",ID="C23E",Class="29LV800T",Category="FLASH",MFG="Macronix",Adapter="TSOP40A-DIP32 adapter",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
Posted - 12/03/2008 :  11:50:47  Show Profile  Reply with Quote
Try to get the ID first before doing anything else.
Close the 3V6 jumper will be 5V.
Close all 3 jumpers will be fine.
Most likely is the contacting problem. Check your pin contacting with the adapter and adapter pin with the programmer.
Your chip is brand new or used?
Can you take a close look picture?
sylverster16v
Germany
Posted - 12/04/2008 :  07:16:05  Show Profile  Reply with Quote
if there is no other way and the chip is dead, which compatible other chips can i buy for MX29LV008CTTC-70G ??
Posted - 12/05/2008 :  02:08:41  Show Profile  Reply with Quote
Not sure if the chip is dead. Jog the adapter little bit after locked it. This will help on pin contacting between adapter and ZIF socket.
sylverster16v
Germany
Posted - 12/12/2008 :  15:40:48  Show Profile  Reply with Quote
i will get Am29LV008BT-70REC ,do you think it is compatible to MX29LV008CTTC-70G and which device should i select in the software?
Posted - 12/12/2008 :  19:34:20  Show Profile  Reply with Quote
Try this:
Name="AM29LV008B",ID="0137",Class="29LV800B",Category="FLASH",MFG="AMD",Adapter="TSOP40A-DIP32",VCC="3.6V",Message="Set the adapter to 5V.";
sylverster16v
Germany
Posted - 12/30/2008 :  17:50:59  Show Profile  Reply with Quote
the datasheet says, the ID has to be 013E ?
59.9 KB
Posted - 12/31/2008 :  22:03:39  Show Profile  Reply with Quote
something wrong with contacting. It should get 013E for the correct ID.
sylverster16v
Germany
Posted - 01/01/2009 :  15:38:55  Show Profile  Reply with Quote
i checked the pin contacting so often,that a dream nights from tsop pins
sylverster16v
Germany
Posted - 01/01/2009 :  17:21:54  Show Profile  Reply with Quote
Now for everyone:
add this line:
Name="AM29LV008BT",ID="013E",Class="SST39LF/VF040",Category="FLASH",MFG="AMD",CodeSize="1048576",DIP="100011110101",Adapter="TSOP40A-DIP32",VCC="3.6V";
and you have to connect A19!(GQ-4X also)
now everything works
Edited by - sylverster16v on 01/02/2009 03:55:46
Posted - 01/01/2009 :  22:13:59  Show Profile  Reply with Quote
Great! It needs A19 address line to be connected.
sylverster16v
Germany
Posted - 01/02/2009 :  03:45:18  Show Profile  Reply with Quote
yes that was the correct answer :)
sylverster16v
Germany
Posted - 01/04/2009 :  07:01:57  Show Profile  Reply with Quote
now i have the correct line for everyone who wants to work with MX29LV008CTTC-70G
Name="MX29LV008CT",ID="C23E",Class="SST39LF/VF040",Category="FLASH",MFG="Macronix",CodeSize="1048576",DIP="100011110101",Adapter="TSOP40A-DIP32 adapter",VCC="3.6V",Message=" "Speed="0" ,Set the adapter to 5V jumper position and connect A19 from adapter to programmer.";
