 Being able to burn TMS2532A
tuc
Posted - 01/26/2025 :  14:35:17  Show Profile  Reply with Quote
So one of the more important chips I'd like to burn is a TMS2532A. It's my understanding that it's not possible with the GQ-4x4 due to not having enough VPP power (25V according to the datasheet I read).
A friend of mine recently ran into the same problem and created an EPROM booster (Though it does have many other uses) to be able to help. (https://youtu.be/cmfbbyea2WM) It'll let you use your bench supply to give power to the chip without having to bend pins out.
I realize that this is one of those "Probably will void your warranty" type things, but if someone was to be willing to take the chance is there anything in the software that would prevent it? (Missing pin sensor that can't be overridden, etc)
Tnx
Tuc
Posted - 01/27/2025 :  13:09:42  Show Profile  Reply with Quote
Originally posted by tuc
Tnx
Tuc
Not to bend pins simply use a small piece of paper bent in the shape of a V in the ZIF socket.
tuc
Posted - 01/27/2025 :  15:44:22  Show Profile  Reply with Quote
Thanks. I could put some shrink tube over it too. But I'm more looking to find that it's because the power to the pin isn't enough, and that the software would program it despite it being "(READ ONLY)".
Tnx. Tuc
Posted - 01/28/2025 :  06:26:04  Show Profile  Reply with Quote
Tnx. Tuc
The GQ-4X goes up to 25V.
tuc
Posted - 01/28/2025 :  13:56:30  Show Profile  Reply with Quote
Ok, so then I guess I don't understand why (TMS)2532A are read only. My theory was low voltage, but if it can do it, then why?
Tnx
Tuv
Posted - 01/31/2025 :  12:56:38  Show Profile  Reply with Quote
Tnx
Tuv
Algorithm?
tuc
Posted - 02/01/2025 :  10:21:01  Show Profile  Reply with Quote
Tnx
Tuc
Algorithm?
Nope, it isn't low voltage as others have said. Its low current.
Tnx, Tuc
Generated in 1.15 sec. Snitz Forums 2000
