| Author |
Topic  |
Bad_Ad84
210 Posts |
Posted - 03/25/2009 : 09:16:30
AT49LV161 ID's fine when selecting AT49LV1614A as device (even tho the chip doesnt say 4A), however when you read it you get back nothing.
But if you set device to say MX29LV160CB and ignore the ID failure it will read perfectly... this was a bug in the willem software too you had to use 29LV160 to read as well.
Any chance of a fix? or is it ok just to add a new device and set the class to 29LV160B? |
Edited by - Bad_Ad84 on 03/25/2009 09:20:52
| Reply #1
2949 Posts |
Posted - 03/25/2009 : 10:32:46
| If you can ID/Read/Eraser/Blankcheck/Write/Verify, then you can just add this chip. If not all commands working, then we have fix it in software. |
| Reply #2
Bad_Ad84
210 Posts |
Posted - 03/26/2009 : 09:10:23
Name="AT49LV1614",ID="1FC0",Class="29LV160B",Category="FLASH",MFG="Atmel",Adapter="TSOP48 8 BIT Mode",VCC="3.6V",Message="Set the adapter to 5V jumper position.";
works perfectly.
which is the same ID as for the AT49LV1614A chip, however i dont have any to test to see if there is the same issue or not. |
Edited by - Bad_Ad84 on 03/26/2009 09:11:06 |
| Reply #3
2949 Posts |
Posted - 03/26/2009 : 10:17:58
| Thank you very much. The devices.txt will be updated with this device line in next release. |
| Reply #4
fox_el_negro
Mexico
19 Posts |
Posted - 04/18/2009 : 22:44:25
i have same problems im using sst39vf160 to program other chips whit the same configuration!!!!!! (29lf160) and others
if i use the rigth configuration the id dont show , if i use the sst39vf160 then the id dtecs the chip!!!.....
PD: also have the parallel willem... buy this new usb and have same problem on same chips... |
c64 |
| Reply #5
2949 Posts |
Posted - 04/20/2009 : 12:49:43
sst39vf160 have to select sst39vf160 from the software. So, what is your problem when selected the sst39vf160 on chip sst39vf160. |
Topic  |
