| Author |
Topic  |
magloman
Sweden
16 Posts |
Posted - 06/17/2009 : 15:08:28
Is it possible to program the flash memory SST27SF010-70-3C-NH with the GQ-3X FW 1.00 ?
I have two PLCC adapters, one wich says "27c64-27c512" with selectable 5v or 3.3v on it, the other saying nothing more than PLCC32 to DIL28 on it.
Which one of these to use if possible ?
The data sheet on the flash: h**p://www.sst.com/downloads/datasheet/S71152.pdf
| Reply #1
2949 Posts |
| Reply #2
magloman
Sweden
16 Posts |
Posted - 06/17/2009 : 23:17:25
OK, that adapter I have.
What device shall I choose, the list does not contain something similar ?
Can I add one to the devices.txt, and what will the settings be in that case ?
And how do I erase it ?
Thanks for the quick answer :-) |
| Reply #3
2949 Posts |
Posted - 06/18/2009 : 00:13:28
You can select SST27SF010 from software.
OR you can add following line into devices.txt file:
Name="SST27SF010*PLCC32",ID="BFA5",Class="27SF010",Category="FLASH",MFG="SST",Adapter="ADP-062, ADP-005 PLCC32-DIP32"; |
| Reply #4
yelenavik
31 Posts |
Posted - 06/18/2009 : 00:13:41
| MAGLOMAN You have both dip28-plcc32,but need dip32-plcc32. |
| Reply #5
magloman
Sweden
16 Posts |
Posted - 06/18/2009 : 04:53:00
Yes of course, NOW when I check it is there to select ! Did not find it before in the list....funny.
Yes, I did not see it was DIL32 instead of DIL28, guess I have to order one.
I having large problems with 27c256 too, starting a new post for that. |
| Reply #6
yelenavik
31 Posts |
Posted - 06/18/2009 : 06:03:43
| for 27c256 need dip28-plcc32 and this one time write device. |
Topic  |
