 Winbond W39v080AP with PCB3B or PCB50
cookie_lu
Posted - 08/11/2009 :  18:54:26  Show Profile
I was wondering how I can flash the above chip with the Willem programmer. The software I have only list W39V040 but not the above chip. Which version of the software should I use?
Posted - 08/16/2009 :  08:33:48  Show Profile
If it is not listed, then most likly it is not supported.
cookie_lu
Posted - 08/17/2009 :  15:42:12  Show Profile
Thanks for your replies.
I will try select SST49LF080A and see what happens.
i was wondering whether it is possible to add new 'device' to the software.
I think I saw ZLM told someone here about adding device by assigning the parameters. W39V040 should be the same as W39V080, just diff capacity, 1 is 512k and the other 1024k.
