 tc89101 y tc89102
osvaldo
Argentina
Posted - 08/16/2009 :  18:51:40  Show Profile  Reply with Quote
hello I need to program a memory gq-4x tc89101 or tc89102 txt me can pass this memory now, thanks
osvaldo tecnico
Posted - 08/17/2009 :  14:54:45  Show Profile  Reply with Quote
can you try to use 93c46 for tc89101? try both 8 bit and 16 bit mode.
use 93c56 for tc89102? try both 8 bit and 16 bit mode.
osvaldo
Argentina
Posted - 08/17/2009 :  16:52:13  Show Profile  Reply with Quote
I try and tell you thanks MRZ
osvaldo tecnico
osvaldo
Argentina
Posted - 08/27/2009 :  19:05:22  Show Profile  Reply with Quote
hello I Hasiendo MRZ prueva as the period mentioned me not working and gives error of this
verification failure, Direcion: 0x000003, dispocitivo: 0xF8 buffer: 0xfc
osvaldo tecnico
osvaldo
Argentina
Posted - 08/27/2009 :  19:42:02  Show Profile  Reply with Quote
Download Attachment: 89101 y 93c46.doc
59.35 KB
osvaldo tecnico
Posted - 09/09/2009 :  08:42:51  Show Profile  Reply with Quote
Try to use slow speed, like "-2".
osvaldo
Argentina
Posted - 09/09/2009 :  19:31:35  Show Profile  Reply with Quote
ok I will provide and inform you if worked
osvaldo tecnico
osvaldo
Argentina
Posted - 09/13/2009 :  16:29:56  Show Profile  Reply with Quote
Hello MRZ prove lower verification error rate and failure illness, Direcion: 0x000002, dispocitivo: 0xF8 buffer: 0xfc
89c101 = 93c46a 8bit and 93C46B 16bit
osvaldo tecnico
Posted - 09/14/2009 :  07:47:25  Show Profile  Reply with Quote
use slower speed.
osvaldo
Argentina
Posted - 09/14/2009 :  16:50:03  Show Profile  Reply with Quote
I tried it does the same
osvaldo tecnico
Posted - 09/14/2009 :  17:02:56  Show Profile  Reply with Quote
can you send testing chip to support@mcumall.com?
osvaldo
Argentina
Posted - 09/14/2009 :  18:55:59  Show Profile  Reply with Quote
I will buy 10 chips in different places and I'll try again and if still the same problem I send the sample from and thanks and keep them informed
osvaldo tecnico
Rhinoman
Posted - 04/29/2013 :  07:35:04  Show Profile  Reply with Quote
Hello
Was this ever resolved? I have the GQ-4X programmer and need to read.write from the 89101. I have looked at the datasheet but, if I'm reading it correctly, it seems to have a different instruction set to the 93C46
Edited by - Rhinoman on 04/29/2013 07:40:07
