 MB85R256 programming
Kastytis75
Lithuania
Posted - 10/03/2009 :  07:27:55  Show Profile  Reply with Quote
Can I use GQ-4X to reprogram this one MB85R256
h**p://www.datasheetarchive.com/pdf-datasheets/Datasheets-12/DSA-233719.pdf
Kastytis75
Lithuania
Posted - 10/15/2009 :  08:39:52  Show Profile  Reply with Quote
Hello
I have tested reprogram it when I selected chip 62256, looks like everything is OK, but I can't write FF's... FF's has been replaced in to 00...why? Can somebody help me?
Posted - 10/15/2009 :  09:21:13  Show Profile  Reply with Quote
This chip is 3.6V chip, but the 62256 is 5V.
Use following line to try:
Name="MB85R256",ID="XXXX",Class="DS1230Y",Category="SRAM",MFG="FUJITSU",VCC="3.6V";
Can you try to fill the buffer with all FF and then write it?
Kastytis75
Lithuania
Posted - 10/16/2009 :  02:03:06  Show Profile  Reply with Quote
Looks like it's working, now I am inserted FF in data...data verification says OK... will test chip little bit later...and will post results
Thanks for help
Kastytis75
Lithuania
Posted - 10/19/2009 :  04:53:25  Show Profile  Reply with Quote
Yes, confirmed...it's working
Thanks for help
