 Problem with enhanced willem and 27cxxx
goukizero
Spain
Posted - 12/10/2009 :  17:06:00  Show Profile
Hello
I just bought an enhanced willem with the 16bit 40-42 dip adapter, it has not extra power supply plug, it just has USB and Parallel port input.
I can read all (27c1024, 27c160, 27c800, 27c000) eproms ok, but i can't write any of them. I ever have the same error : 0x000000 chip = 0xff or 0x00 and buffer 0x00 or 0xff It depends about the bin file i want to use.
Well, I used all the combinations i could do with the wires, the programmer, the adapter. I ever get an error.
I can read all of them, so I suppose the Willem works...
I'm really desperated.
If you can help me, please !!!
Posted - 12/15/2009 :  09:42:55  Show Profile
Use a 9v or 12v external power adapter to see if it works.
simeon
Posted - 01/23/2010 :  07:05:50  Show Profile
you can still use it by adding a small jumper between the vcc pin 32 and 28 on there tracks
when you want to program you can add 6.250 here from a small supply of 9vdc and using a three pin voltage regulator 5.1v and add some diodes to its ground pin to raise its voltage output to 6.2 {ie two diodes for 1.2v}{this is aok for reading also}
p5b asus main machine
legacy detection enabled
Generated in 0.36 sec. Snitz Forums 2000
