 Support for M48T129Y
bandjel
Posted - 12/15/2009 :  07:08:43  Show Profile  Reply with Quote
Are you going to support M48T129Y? I need to program this chip. I can get sample for testing.
Best regards!
Posted - 12/15/2009 :  07:43:58  Show Profile  Reply with Quote
This M48T129Y will work.
bandjel
Posted - 12/15/2009 :  09:09:07  Show Profile  Reply with Quote
There are no such device in option of USBPrg5!
Posted - 12/15/2009 :  09:33:41  Show Profile  Reply with Quote
You can add this device.
Add following lines into devices.txt:
Name="M48T129Y",ID="XXXX",Class="BQ4015",Category="SRAM",MFG="ST",VCC="5.5V",PINVCC="ZIF32_PIN32",CodeSize="131072",Package="DIP32";
Name="M48T129V",ID="XXXX",Class="BQ4015",Category="SRAM",MFG="ST",VCC="3.6V",PINVCC="ZIF32_PIN32",CodeSize="131072",Package="DIP32";
Please let me know if this works.
bandjel
Posted - 12/15/2009 :  09:38:24  Show Profile  Reply with Quote
Ok, I will let you know. I need some time to get samples. Thanks
bandjel
Posted - 02/13/2010 :  03:40:58  Show Profile  Reply with Quote
Ok, there are some tests.
M48Z128Y is OK, read, write, verify. The BEST!
Name="M48Z128Y",ID="XXXX",Class="BQ4015",Category="SRAM",MFG="ST",VCC="5V",PINVCC="ZIF32_PIN32",CodeSize="131072",Package="DIP32";
M48T129Y
Read is NOT OK. Always shows error only on adresses 1FFF9 and 1FFFA, unstable reading, different values.
Writing is always OK. This function is compared with ELNEC SmartProg.
Verifiying is like Read, unstable on adresses 1FFF9 and 1FFFA
Do you have some idea to resolve this problem?
Edited by - bandjel on 02/13/2010 12:17:12
Posted - 02/13/2010 :  22:15:02  Show Profile  Reply with Quote
Try this line:
Name="M48T129Y",ID="XXXX",Class="BQ4015",Category="SRAM",MFG="ST",VCC="5V",PINVCC="ZIF32_PIN32",CodeSize="131072",Package="DIP32",Speed=3;
bandjel
Posted - 02/16/2010 :  02:20:24  Show Profile  Reply with Quote
I have tried , already, manually, to change speed factor, but no result. But, at this moment, I don't have any samples to try.
Posted - 02/16/2010 :  14:08:39  Show Profile  Reply with Quote
This one voltage changed to 5V maximum.
bandjel
Posted - 02/25/2010 :  15:04:48  Show Profile  Reply with Quote
New test. Nothing news with M48T129Y! Same problem with memory reading at adresses 1FFF9 and 1FFFA. I made many combination with Vcc, Speed, but nothing good. Always unstable reading. Writing is good comparing with Elnec SmartProg.
Posted - 02/27/2010 :  22:56:10  Show Profile  Reply with Quote
Can you try the 5.01 beta?
http://www.mcumall.com/download/TrueUSBWillem/GQUSBPrgRe5.01Beta.exe
bandjel
Posted - 03/08/2010 :  10:05:28  Show Profile  Reply with Quote
D'ont work! Same situation with version 5.00.
Posted - 03/08/2010 :  17:57:03  Show Profile  Reply with Quote
If the slower speed does not work with Re5.01Beta, thenI think we need a testing chip to reproduce the problem.
