 27c4002 on GQ-3X failing
tak
Switzerland
Posted - 12/17/2009 :  10:46:43  Show Profile  Reply with Quote
hi,
I have several 27c4002 here and not able to program any of it. I tried several speed settings and erased them over and over again (UV).
H/W Re: GQ-3X Re-1.00
USB Driver Re.2.0
Software Re. 5.0
<<27C4002>>
ID check skipped
Reading... Code
Elapsed time: 3.43 seconds.
Read completed.
ID check skipped
Blank checking... Code
Chip is blank
Speed = 3
Speed = 5
ID check skipped
Writing... Code
Elapsed time: 14.36 seconds.
Write failed, Address=0x000000, Buffer=0xFF Device=0x01
Write failed
I have the correct 16bit adapter, which I use with success to flash 27c322 chips.
is this a know issue with 27c4002 and a workaround available?
thanks in advance
~tak
osvaldo
Argentina
Posted - 01/09/2010 :  21:50:26  Show Profile  Reply with Quote
Hello 27C4002 tak try another if he tried another and it does not check that the adapter parts of the welding or the anchoring of where the chips will
osvaldo tecnico
osvaldo
Argentina
Posted - 01/09/2010 :  21:53:37  Show Profile  Reply with Quote
foto de adaptador circuito
Download Attachment: 16BitSchematic.pdf
15.15 KB
osvaldo tecnico
tak
Switzerland
Posted - 01/10/2010 :  03:18:10  Show Profile  Reply with Quote
thanks for the help. I'm already in contact with the mcumall support and will send one of my chips to them (was busy over christmas/new year) for further testing. I've tested in the meantime a 27c4096 which works flawless.
osvaldo
Argentina
Posted - 01/10/2010 :  19:01:01  Show Profile  Reply with Quote
ok mis saludo y feliz aņo tak
osvaldo tecnico
tak
Switzerland
Posted - 01/30/2010 :  02:23:26  Show Profile  Reply with Quote
any news on this topic? has my sample been arrivied?
Cheers,
tak
Posted - 01/30/2010 :  22:06:29  Show Profile  Reply with Quote
Received the testing chip. But did not find anything wrong. It programmed and verified on my GQ-4X and ADP-054 without any problem.
tak
Switzerland
Posted - 01/30/2010 :  23:00:47  Show Profile  Reply with Quote
great news than! thank you very much for the testing. so it looks like my ADP-054 is broken than. funny part is that I was able to write 27c4096 :(
Posted - 01/30/2010 :  23:08:46  Show Profile  Reply with Quote
do you still have another M27C4002 for testing? I just want to know you still can produce the same problem. I want to know the exact problem when doing programming.
Posted - 02/01/2010 :  16:54:05  Show Profile  Reply with Quote
chip will back to you soon.
