 GQ4X--------->AM29F010
kaleteam
Reunion Island
Posted - 01/24/2010 :  04:22:41  Show Profile  Reply with Quote
hi,
i try to read a AM29F010 with PLCC32 package chip & I am using the PLCC32-DIP32 Adapter.(ADP-005)
I selected the AM29F010 from the device list.and i select read, i have a error message, "ID check échoué.Verifier le type de l'Eprom , qu'elle soit correctement insérée,et le bon contact des pattes.
Some OEM chips may have compatible chip ID"
can you say me what's the problem please?
Posted - 01/24/2010 :  08:08:52  Show Profile  Reply with Quote
1. Check pin contacting.
2. Check chip pin 1 orientation
3. Reposition the chip and adapter.
4. Try second chip
kaleteam
Reunion Island
Posted - 01/25/2010 :  01:11:29  Show Profile  Reply with Quote
if I have an EPROM M27C512 PLCC32 by what can I replace this one?
kaleteam
Reunion Island
Posted - 01/25/2010 :  09:37:41  Show Profile  Reply with Quote
I tried 3 EPROM and the result is the same, no ID! When I choose to read an EPROM M27C512 By selecting the VCC LED remains lite fixe.I think I have a problem with the programmer and adapter.
Posted - 01/25/2010 :  10:03:50  Show Profile  Reply with Quote
The M27C512 PLCC32 chip should use PLCC32-DIP28 adapter, which is ADP-006
See:
http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=3105
However, the VCC LED should go off after ID the chip.
Please remove the chip from the programmer and then click on ID again. This will check if the VCC will go off or not.
kaleteam
Reunion Island
Posted - 01/26/2010 :  05:36:17  Show Profile  Reply with Quote
For the M27C512 t=it's ok after restart computer, but for AM29F010 i think problem with ADP-005,bad contact in soldering.
kaleteam
Reunion Island
Posted - 01/26/2010 :  09:04:01  Show Profile  Reply with Quote
I confirm that the problem was well adapter ADP-005, I had recently ordered but never used, I had this problem and I found the solution, the pins are weld defects at the 'adapter. Just make new welding and it works now.
