 In-Circuit Programming SOIC8
Kozuka
Posted - 04/21/2010 :  12:59:48  Show Profile  Reply with Quote
I have a Winbond w25x80*soic8
Originally I got it to ID correctly with a soic8 cable and without the SPI booster. Now its been about a week I got a new clip and the SPI booster and now it wont ID at all been messing with this thing for hours. It seems to stall (the application) up when I have power power hooked up to my motherboard. Very hit or miss and very frustrating.
Can anyone help?
Thanks,
Kozuka
Kozuka
Posted - 04/21/2010 :  13:13:02  Show Profile  Reply with Quote
Mostly when I try and ID I get this signature length error.
Kozuka
Posted - 04/21/2010 :  14:19:11  Show Profile  Reply with Quote
Alright so I got in contact with John and he said,
If you powered you mother board, then the adapter ADP-056 power select jumper should select 2-3 from the target board.
Also, do not connect VCC line, only connect the chip pin 1,2,4,5,6.
Check the chip pin 3,7 and they should stay hi at any times.
Which I did and responded.
pins 3,7 Are at around 2V with a multimeter, jumpered 2-3 on in-circuit
board hooked up 1,2,4,5,6 to the spi interface. Gives a device ID of
000000
