 TC571001D-20
emudrache
Posted - 10/02/2010 :  05:23:49  Show Profile  Reply with Quote
Can the GQ-4X support this chip?
hxxp://www.datasheetarchive.com/pdf-datasheets/Databooks-2/Book291-142.html
Posted - 10/02/2010 :  07:42:17  Show Profile  Reply with Quote
Yes. It should be supported. Select MBM27C1001 from software. They are compatible devices.
emudrache
Posted - 10/02/2010 :  08:01:00  Show Profile  Reply with Quote
thanks
i think that worked
Posted - 10/02/2010 :  23:07:42  Show Profile  Reply with Quote
Oops!
Thanks to EZoSat.
emudrache
Posted - 10/03/2010 :  01:50:45  Show Profile  Reply with Quote
so that would explain the discrepancies in the data that was read.
had huge chunks of FF in it. i had assumed that it was bad so i
was searching for replacement.
so no way to read this at the moment unless i swap 2/24 and read with MBM27C1001 settings ?
i may try that later see what happens.
Thanks EZoSat
Edited by - emudrache on 10/03/2010 01:52:07
emudrache
Posted - 11/03/2010 :  13:39:05  Show Profile  Reply with Quote
didnt work :( tho it was pretty hack-ish the way i tried.
