 ST49LF002A(B)
syntax
Netherlands
Posted - 08/27/2006 :  11:02:26  Show Profile  Reply with Quote
I want to program a ST49LF002A(B) it seems that i need another adapter (got 2 adapters with the kit, a plcc32-to-dip32 and plcc32-to-dip28 for 27cXX) It seems that i need the FWH/LCP+ adapter, is that the same as the ADP-008 FWH/HUB Adapter? ( since the FHW/LCP+ isnt in the adapter-shop )
Let me know.
Syntax
Posted - 08/28/2006 :  16:38:34  Show Profile  Reply with Quote
The FHW/LCP+ adapter is not available in the store yet. But FHW/LCP+ is the modified version of FHW/LCP. You may need a modified FHW/LCP.
syntax
Netherlands
Posted - 08/29/2006 :  12:51:13  Show Profile  Reply with Quote
Thanx, found it out through the support ( placed a order, The representitive notified me that i needed a modified fhw/lcp adapter. )
Also if you want to program the AT89LV51,52,55 you should not order the "MCS-51" adapter as mentiond by the software, but the "ADP-001 ATMEL89 (51 AVR )Adaptor"
