Making sure...
mike
Posted - 11/27/2006 : 09:40:10
Just to make sure.... I want to program 2732-2764's and 28C64's .. can the True Programmer make enough voltage/current for these just from the USB port? .....
has anyone programmed these with it? ... your results? ...
Regards... Mike
Posted - 11/27/2006 : 23:24:59
Those chips are supported. Otherwise it will be fixed.
If you have exact part number, then you can check the supported list in the software.
Edited by - ZLM on 11/27/2006 23:30:23
Generated in 0.42 sec.
