 Tutorial for adding device and Dip switch
william_ht
Posted - 12/24/2006 :  14:04:33  Show Profile  Reply with Quote
Can someone post a tutorial for:
- adding new devices
- setting Dip switches
It is essential that we increase the number of devices handled by this USB programmer in order to compete at par with standard LPT willem programmers or outbeat them.
I believe all of us can help to make it happen!
Posted - 01/03/2007 :  03:10:33  Show Profile  Reply with Quote
Currently has no official tutorial yet. Only info available is in the help of the software.
There are some info I know:
1. The new device can be added into the device search list by modifying the devices.txt.
2. The new device is based on the existing chip family, it's called "class" in the devices.txt file. They are sharing same read/write algorithm. Only different on size, speed, voltage, package. So that you can add the new devices based on the same class. The class is the predefined algorithm collection, user is unable to change the class for now.
3. You have to follow the syntax in the devices.txt file.
4. The new dip setting is by "DIP=", example: "DIP=100010110000". for total 12 bit DIP switch. 1 or 0 for one bit DIP switch ON or OFF.
Edited by - ZLM on 01/03/2007 03:12:08
