 Compatibility with old Willem FWH / LPC adapters
effesse
Italy
Posted - 12/13/2011 :  11:20:12  Show Profile  Reply with Quote
Dear MCUMALL / ZLM good morning, I need to modify my 2 FWH/LPC adapters used on Willem v3b in order to use them again on the new GQ-4X. Can you help me to understand if I have to apply the CUT & WIRE mod on the top layer or in the bottom layer? And the Green LED will works the same way? Thank you in advance, best regards, Stefano.
Effesse72
Edited by - effesse on 12/13/2011 11:21:05
osvaldo
Argentina
Posted - 12/14/2011 :  20:15:56  Show Profile  Reply with Quote
Lo mejor es comprar a mcu el adaptador PARA EL GQ3 Y 4 para no estar haciendo modificaciones y no dañar el producto y que no pierdas la garantía del fabricante. y mándale un mail a mcu con la fotos de los adaptadores de los dos lados para que tengan mas información desde ya gracias
osvaldo tecnico
Posted - 12/15/2011 :  11:23:38  Show Profile  Reply with Quote
See similar mode:
17.49 KB
70.15 KB
effesse
Italy
Posted - 12/17/2011 :  06:59:17  Show Profile  Reply with Quote
Thanks a lot ZLM for your great support, it worked for me!
Where/How can I insert the Green Led diode in order to make it work again?
I suppose wired together to A15 (PIN 7 of ZIF 40) it could demage the GQ-4X, right?
Which pad/signal/scriptddress of the FWH/LPC can I use to make the Green Led to work as with the Parallel Willem?
It would be usefull to turn on the Green Led when I use the VPP signal not the VCC. Can you suggest to me how can it be done?
Thank you again for all your replies, best regards, have happy X'mas time, Stefano.
79.4 KB
Effesse72
Edited by - effesse on 12/17/2011 14:15:25
Posted - 12/21/2011 :  08:39:49  Show Profile  Reply with Quote
The original modification is a simplest way in order to work with the GQ True USB Programmer.
If you want let LED to work, then you can try connect the A15 to LED + side to make the LED ON, but you may need to reduce or short the R5.
effesse
Italy
Posted - 12/29/2011 :  10:50:56  Show Profile  Reply with Quote
Thank you very much again ZLM for your amazing support. I will try to do this way as soon as possible; I will try with about 1K value of R5 and I will post here the results. Best regards, have nice holidays, Stefano.
Effesse72
