 Identifing file formats
_enerjay
Posted - 02/12/2012 :  10:16:42  Show Profile
GQ-4X with software version 6.13
I have a BIOS file for a MSI G31T M-P35 (MS-7529) motherboard with the filename A7529IMS.470
When i open the file the dialog box shows .bin as the file format. Does the software parse the file and detect the correct file format or do i have to select it from the drop down menu.
If i do have to select the format how do i work out which format to choose.
If i'm missing something obvious please enlighten me
Regards
Jason
Edited by - _enerjay on 02/12/2012 11:54:46
Posted - 02/15/2012 :  00:00:41  Show Profile
The software recognize the .bin .hex file format.
Confirm your file type .470 is in bin file. Then you can use .bin file format to open it.
