 29F200BB Not Detected on PCB5.0
bangreno
Burkina Faso (Upper Volta)
Posted - 05/16/2012 :  01:41:08  Show Profile
I've to programm 29F200B , selected Flash 8/16 bit TSOP48, AMD, AM29F200 .
chip Not Detected in Software 98D12C3
But When I select Flash 16 Tsop48 , Chip is identified as fujitsu , but Erasing and Writing fail.
Chip Come from a Rernault Espace Sirius 32 ECU.
Any hardware Hint ?
LeBoss
Posted - 05/16/2012 :  05:01:58  Show Profile
Make sure your programmer has no problem.The chip is good chip, and the adapter is good.
This chip should be identified correctly. Not the "fujitsu "
bangreno
Posted - 05/17/2012 :  11:13:37  Show Profile
I'll need to get another chip to check.
Adapter I checked many times.
LeBoss
mexanico1971
Portugal
Posted - 01/13/2015 :  16:40:47  Show Profile
Hi !
bangreno how do you solved you problem ?!
thank"s in advance
BR
