 16f628 verify /prog problems.
Sarah_B
Posted - 08/31/2013 :  11:57:34  Show Profile  Reply with Quote
Hi.
I'm getting the following error when I program a
pic16f628-04 using my gq-4x. and re 6.23 software.
op-sys is win7/64-bit. code compiled with no probs
using mpasm
Any ideas.?
Erasing...
Elapsed time: 0.87 seconds.
Erase completed.
ID check OK
Writing... Code
Elapsed time: 11.15 seconds.
Device write completed OK
ID check OK
Writing... Data
Elapsed time: 0.01 seconds.
ID check OK
Writing... User ID
Elapsed time: 0.00 seconds.
ID check OK
Verifying... Code
OK
Elapsed time: 2.45 seconds.
ID check OK
Verifying... Data
OK
Elapsed time: 0.33 seconds.
ID check OK
Verifying... User ID
Verify Failed, Address=0x000000, Device=0x13, Buffer=0x53
Verify Failed
Elapsed time: 17.80 seconds.
Sarah_B
Posted - 08/31/2013 :  12:00:50  Show Profile  Reply with Quote
config settings and userID are failed / corrupted too.
Sarah B
feravalos94
Mexico
Posted - 03/23/2014 :  19:22:21  Show Profile  Reply with Quote
Hi! I'd like to know how you solved your problem, because I'm having the same issue with a similar pic :/
thank you
Posted - 04/01/2014 :  12:21:18  Show Profile  Reply with Quote
can you let me know your CFG word value you are trying to write? and what you read back after write? I can check it for you.
