 SST39SF040 Trouble
Malcolm
Canada
Posted - 03/17/2007 :  12:07:12  Show Profile  Reply with Quote
Hello,
Just having trouble erasing SST39SF040
It said erase complete, but the screen is not FF...
- Dip switch is correct, Chip in the right position.
***Error***
BlankCheck: Device is not blank at address: 0x0, device read 0x2.
Varify: Device verify failed at address: 0x3c000, device read 0x0, buffer is 0xff
***Error***
Malcolm
Posted - 03/17/2007 :  16:25:53  Show Profile  Reply with Quote
If the chip ID and reading are correct, then the chip may be a damaged chip.
Malcolm
Canada
Posted - 03/18/2007 :  22:31:39  Show Profile  Reply with Quote
Thanks you are correct, the chip was damage.
MikeHunt79
Posted - 12/02/2009 :  11:59:37  Show Profile  Reply with Quote
Malcolm, where did you buy a placement EEPROM? I think my sst39sf040 may be bad also, do you know where I could purchase a replacement?
How much wood would a woodchuck chuck if a woodchuck could chuck wood?
