 6.29 Not Displaying Properly
briank9803
Posted - 05/02/2014 :  18:40:27  Show Profile  Reply with Quote
Okay, this is the 5th problem in trying to get 6.29 GQ-4X to work. IMHO this software does not work. The latest problem is the right panel, which displays speed settings, chip orientation, etc. does not display or incomplete display on Windows 8.1.
Has anyone gotten 6.29 to work? Properly?
____________
Brian
Posted - 05/05/2014 :  10:46:58  Show Profile  Reply with Quote
What is your windows version? this should be fixed in this version.
briank9803
Posted - 05/05/2014 :  13:04:15  Show Profile  Reply with Quote
Windows 8.1. I installed software on another computer running Vista. Displays fine. But as an end-user, this "problem" should have been noted in the instructions for installing on Windows 8.
____________
Brian
toprak
Posted - 06/24/2014 :  05:23:53  Show Profile  Reply with Quote
Ahoi,
GQ-4X True USB Universal Pogrammer
OS: Windows 8.1
Software Revision: 6.29
I've got the same problem and it is quite annoying. Is there any solution? Thanks in advanced.
Kind regards,
Toprak
P.S.: Maybe there should be an update in the "About/Copyright"-Section, too ;)
39.71 KB
31.98 KB
5.57 KB
areinike
Posted - 07/03/2014 :  11:48:17  Show Profile  Reply with Quote
I have the exact same issue. Windows 8.1 is not the same as Windows 8. I am running an nVidia Graphics adapter if that helps.
Posted - 07/05/2014 :  12:23:47  Show Profile  Reply with Quote
Try this Re6.30 build:
http://www.mcumall.com/comersus/store/mcumall_download.asp
