 Help Programming AT29C010A
ian8115
Posted - 03/29/2007 :  08:12:57  Show Profile
Hi. I have recently purchased a Willem Programmer running 0.97ja. I am trying to program an AT29C010A. I have a 5V USB power source and is connected to my Printer port on my Laptop running XP.
I have connected pin 3 to 31.
It will read, verify, and blank check ok but cannot get it to program.
It says Error: Write Sector 0
What I did do by accdent was read then immediately write then it worked but that was just rewriting back to the chip.
I cannot get the 128k File (for car tuning) to the chip. Any help would be much appreciated.
Thanks, Ian
Posted - 03/30/2007 :  07:59:46  Show Profile
What is the "I have connected pin 3 to 31."??
You should be able to get correct ID. Did you??
ian8115
Posted - 03/30/2007 :  09:31:36  Show Profile
Problem solved! The chip wont write if the chip is pushed all the way in to the PLCC sucket. If I push it in a little bit it writes fine. Must be dodgey plcc adaptor.
My next question, Is the 27C1001 same as 29c010? Thanks
Posted - 03/31/2007 :  00:55:35  Show Profile
No. Those are different chips.
ian8115
Posted - 03/31/2007 :  08:41:24  Show Profile
That explains alot. It was to replace a 27c1001 in an ECU. How about the 29f010? Thanks
Posted - 04/01/2007 :  14:55:49  Show Profile
Depend on your ECU circuit, there is high possibility to replace 27c1001 by 29f010 or 29c010. On pin 31 of chip, it must stay on 5V for 29F010/29c010. But 27c1001 does not care this pin.
The 29c010 has same requirement too.
ian8115
Posted - 04/02/2007 :  10:05:06  Show Profile
Oh i see. They were originally 27C1001. What would you recommend? Thanks
Posted - 04/02/2007 :  20:46:39  Show Profile
Check original 27C1001 circuit and see if the pin 31 connected to somewhare. If that pin is not connected to anywhere, just short the pin 31 to 32 on 29F010/29c010.
