 TOP2005 Topwinen v2.35 Config
Goonie
Australia
Posted - 04/18/2007 :  05:51:18  Show Profile
I am having problems getting my PIC (16F877) to work. I've tried my code on other programmers and it has worked fine and when using the TOP2005 it seems to write and read correctly, but doesn't work so I can only assume it's the config. To make things a bit more difficult the manual I got with the programmer doesn't have the config screen that comes up in my version of Topwinen so I don't actually know what most of them mean. If anyone knows and can help I'd much appreciate it. They are as follows:-
FOSC0
FOSC1
WDTEN
PWRTE
CP0
CP1
BODEN
LVP
CPD
WRT
RESV
CP0
CP1
It also says "Config(Cheoked=0)". I gather it should say "checked" and saying checked = 0 means if I tick the box next to the function it is off, does that sound right, I'm used to ticking boxes meaning on? I'm also not sure why CP0 and CP1 are shown twice.
Any help would be great.
Cheers,
Markus
CostaRica
Costa Rica
Posted - 04/29/2007 :  19:51:43  Show Profile
I had the same problem with my top2004, the solution is very easy,you have to read the data sheet of the pic16f877A in the seccion named CONFIGURATION WORD (ADDRESS 2007h)(1) in my case is the page number 146 of the .pdf or you can try it with this configuration(please tell me what happens with your new configuration at emamacu@yahoo.com):
FOSC0 ô
FOSC1
WDTEN ô
PWRTE ô
CP0
CP1
BODEN ô
LVP ô
CPD
WRT
RESV
CP0
CP1
