 GQ-3X 29F800 only 50%?
nbdey
Posted - 08/21/2014 :  08:23:14  Show Profile  Reply with Quote
Hello I got a GQ-3X ( from zeitech.de) and got never problems with it.
I use the ADP-019 V2.1
But now I´ve to write a 29F800BB (tried a BT too, but same problem) and the Willem stops at 50% and I´m confused...
I think I must bridge the Pin A19 on the Adapter to Pin A19 on willem, but there are two of them, I tried both, but same result...
Can anyone help me? Maybe tell how the right way should be?
Posted - 08/29/2014 :  20:36:19  Show Profile  Reply with Quote
see:
http://www.mcumall.com/forum/topic.asp?TOPIC_ID=4729
nik7dob@gmail.com
Bulgaria
Posted - 03/17/2015 :  09:23:08  Show Profile  Reply with Quote
Any further information about this issue?
Posted - 03/18/2015 :  15:05:14  Show Profile  Reply with Quote
Connect A19 on GQ-3X to adapter.
ZRimas
Posted - 05/27/2019 :  05:42:29  Show Profile  Reply with Quote
I have similar issue - programmer GZ-4X, adapter PSOP44-DIP V2 ADP-019 (original from mcumall)- I can't program 29F800 more than 50%. Jumper set to 29F, id reads correctly, reads full flash - also, erases - OK, but when I start writing, it freezes on 50% with red led on on the programmer.
What I'm doing wrong?
Posted - 05/27/2019 :  07:18:00  Show Profile  Reply with Quote
Both halves of the read are good?
ZRimas
Posted - 05/27/2019 :  07:46:41  Show Profile  Reply with Quote
Hmmm. Not shure. Checked my read files, looks like they are ok, but I do not have any 'untouched' 29F800 to check it.
EDIT:
Now I tried on more time:
I have the original file for 29F800, read from ECU by OBD - it has no doubled information after address 0x8000h.
What I did:
- erased 29F800
- checked - it has all FFs
- tried to write original file, read by OBD
- programmer stopped at 50%
- disconnected programmer, connected again and read what has been written - it has doubled information, it means 0x0000h-0x7FFFFh has it's copy from 0x80000h
Edited by - ZRimas on 05/27/2019 08:17:28
Posted - 05/27/2019 :  08:35:20  Show Profile  Reply with Quote
EDIT:
What I did:
- erased 29F800
Check if A19 is communicated from the ZIF socket to the chip.
ZRimas
Posted - 05/27/2019 :  08:59:42  Show Profile  Reply with Quote
OMG!!! Somebody (probably ME!) removed A19B pin from the adapter! Soldered new one, everything is working!
Thanks a lot, anniel!
Posted - 05/27/2019 :  09:52:08  Show Profile  Reply with Quote
You're welcome!
The 4 top pins of the adapter need to be removed only for the older programmers.
