 GQ-4X reading 24c256l
NovaSec
Posted - 09/22/2014 :  09:49:50  Show Profile  Reply with Quote
Is there a way to protect the code on a 24C256L, read loads of these in the past but had a couple now that i cant read in circuit, could the circuit be a problem ? or can it be protected ?
Posted - 09/22/2014 :  17:47:35  Show Profile  Reply with Quote
check you 24C256L chip address pins. The software can change the address by click the CFG button.
NovaSec
Posted - 09/24/2014 :  09:59:53  Show Profile  Reply with Quote
Thanks, tried another chip from a different panel today and the same. Just looked at CFG button and it gives me 3 options will have a read.
NovaSec
Posted - 09/24/2014 :  22:18:18  Show Profile  Reply with Quote
Tried CFG and selecting a changing the address still nothing
NovaSec
Posted - 09/26/2014 :  06:44:40  Show Profile  Reply with Quote
Tried another today and the same nothing, can anybody help me out on this.
Posted - 09/26/2014 :  14:52:11  Show Profile  Reply with Quote
If your board CPU controls this chip, then you are unable to read/write the chip while the CPU occupied it. In this case you need to de-solder the chip and program it on the programmer ZIF socket.
NovaSec
Posted - 09/27/2014 :  01:26:06  Show Profile  Reply with Quote
I tried a different chip from the same but older panel that has a DIL socket for the eeprom, removed it and tried to read it all blank again.
NovaSec
Posted - 09/28/2014 :  06:23:55  Show Profile  Reply with Quote
Just dusted of a old serial programmer, and used IC Prog to read this chips without a problem, can something have gone wrong with my GQ-4X never had issues before.
Posted - 09/30/2014 :  07:39:38  Show Profile  Reply with Quote
If your chip can be easily removed from the board, then you can just program it on the programmer. That should not have problem.
NovaSec
Posted - 09/30/2014 :  11:17:53  Show Profile  Reply with Quote
The last one i tried was socketed DIL so easy removed, tried in GQ-4x nothing then as per post 7
could i have changed something in the software ???
Posted - 09/30/2014 :  11:53:30  Show Profile  Reply with Quote
In oder to change the sofware, we need to repeat the problem here and know what is the software problem.
