 Device support for 25B64BS
rado_tm
Bulgaria
Posted - 01/29/2015 :  01:15:20  Show Profile  Reply with Quote
Can someone help ? Is this device supported by Gq-4x ?
I'm getting ID code : C84017
Think Ic is EN25B64BS
GQ-4X
laptech
Posted - 01/29/2015 :  05:22:37  Show Profile  Reply with Quote
I found a datasheet for a EN25B64, h**p://www.essi.com.tw/upfile/p2008929183619.pdf i wonder if this is the same chip. On page 16 you will notice it's code is 1C2017
Laptronics UK LTd. Specialist motherboard repair.
rado_tm
Bulgaria
Posted - 01/29/2015 :  08:01:00  Show Profile  Reply with Quote
I'm Attaching a photo of ic
148.57 KB
GQ-4X
laptech
Posted - 01/29/2015 :  08:24:02  Show Profile  Reply with Quote
Looks like you have the same problem I had with these similar made chips. They are made by company called GigaDevices of which the GQ-4x does not support. I got help with a GD25Q80 and the data for these devices are very similar. You will need to add the following line into the devices.txt file, make sure you put it in the 'Serial Eprom' section. It should work. I added a file for a GD25Q32 based on the info ZLM provided and what other info i saw in the text file so the line I've provided should work for your chip. Or you can wait for ZLM to confirm what i have written.
Name="GD25B64BSIG",ID="C84017",Class="W25X10",Category="SERIAL_EPROM",MFG="GigaDevice",Vcc="3.6V",CodeSize="8388608",Adapter="ADP-081, ADP-027 adapter",Platform="GQ-4X";
Posted - 01/29/2015 :  23:22:19  Show Profile  Reply with Quote
Based on the datasheet, the ID should be "1C2017".
Name="GD25B64BSIG",ID="1C2017",Class="W25X10",Category="SERIAL_EPROM",MFG="GigaDevice",Vcc="3.6V",CodeSize="8388608",Adapter="ADP-081, ADP-027 adapter",Platform="GQ-4X";
pashha
Turkey
Posted - 01/27/2020 :  08:26:48  Show Profile  Reply with Quote
i pasted it correctly into the serial eeprom section. i can see it now but under manifaturer is written : Apple ! and i,t gives error by reading it. something is wrong with ID i guess
GQ-4X
Posted - 01/27/2020 :  09:49:00  Show Profile  Reply with Quote
Which ID do you get?
pashha
Turkey
Posted - 01/29/2020 :  04:06:32  Show Profile  Reply with Quote
c84017 (or maybe someone tell me a replacement chip wich is supported by gq-4x
GQ-4X
Edited by - pashha on 01/29/2020 04:23:31
Posted - 01/29/2020 :  04:50:00  Show Profile  Reply with Quote
C84017 is a GD25Q64 not a GD25B64.
Posted - 01/29/2020 :  05:21:11  Show Profile  Reply with Quote
Try with Name="GD25B64BSIG",ID="C84017",Class="W25X10",Category="SERIAL_EPROM",MFG="GigaDevice",Vcc="3.6V",CodeSize="8388608",Adapter="ADP-081, ADP-027 adapter",Platform="GQ-4X";
