 Solution: prevent from exit-crash after GAL-Mode
joegermany
Germany
Posted - 05/24/2007 :  08:43:05  Show Profile
Hi Folks
After using a PAL/GAL menu, most versions of topwin??.exe
crash when trying to exit the program.
There are two possible solutions:
1) select any other device (no gal/gal) before exit.
or
2) start topwin??.exe
select a device, but NO GAL/PAL
exit the program
write-protect the cfg.file (in my case it is the top2004.cfg)
restart the program
Since the error-on-exit seems to have the reason in writing the
config file, it now works fine in my installation. Of course,
now the last used device is not stored any longer, but that should
not be problem.
Jochen Müller
Edited by - joegermany on 05/24/2007 15:00:10
Posted - 05/25/2007 :  00:56:36  Show Profile
Thanks for the info.
