 AM29F080B - TSOP40B-D
teknix1
Posted - 09/23/2015 :  05:19:36  Show Profile  Reply with Quote
I need a bit of help. I've got a GQ-3X Rev 1.00 and will be using it to program an AMD AM29F080B (TSOP-40). When selecting the chip in the software, it tells me I need to use a TSOP40B-D adapter. I can't seem to find it in the store, I see the TSOP40A, but not TSOP40B. I don't know what the -D means at the end. I also read elsewhere that I simply need to remap the pins from the TSOP chip to a DIP format, no adapter chip or logic needed. The adapters for sale seem to do more than that. Furthermore, I plan on soldering this chip on a adapter DIP board which I hope to be able to just place in the programmer. Possibly my adapter board might re-order the pins because of my projects needs, so I would end up having to create a second adapter board for the programmer.
So I guess it's a long story, but any suggestions on what to get or what to do? I guess if I knew what pins the programmer is expecting and where on the ZIF socket, I could just make my own adapter boards. Where can I find this mapping?
Any info is appreciated, thanks!
Nic
Posted - 09/25/2015 :  07:02:55  Show Profile  Reply with Quote
The adapter base board should be ADP-082 now:
http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=4418
The top part is ADP-077:
http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=4405
teknix1
Posted - 09/28/2015 :  11:15:39  Show Profile  Reply with Quote
Hi ZLM,
I apologize for the late reply. I have since ordered and received those two boards. One of them has a lot of jumpers, is there a document somewhere that explains what they do?
I've also discovered an issue in devices.txt. There is a return carriage right after the D in "TSOP40B-D", if you take it out, the software can now display the full adapter name which is "TSOP40B-DIP32". Makes more sense.
Nic
Hernan
Argentina
Posted - 09/28/2015 :  15:58:08  Show Profile  Reply with Quote
http://www.mcumall.com/forum/topic.asp?TOPIC_ID=4729&SearchTerms=gq-3x
Edited by - Hernan on 09/29/2015 05:59:58
Posted - 09/30/2015 :  14:33:52  Show Profile  Reply with Quote
Keep original jumper settings.
The only jumper you need to set is J3. Make sure you set it on 5V position.
teknix1
Posted - 10/01/2015 :  12:32:07  Show Profile  Reply with Quote
Thanks again. It was already set to 5V. Sorry to ask again, but is there any docs on this? I'm finding hard to understand how these adapters work together and when to choose what there must be a site somewhere with more info.
teknix1
Posted - 10/01/2015 :  12:33:51  Show Profile  Reply with Quote
My apologies Hernan, looks like I missed your post. I can't seem to find my two adapters on that page, ADP-082 and ADP-077.
Posted - 10/05/2015 :  22:19:05  Show Profile  Reply with Quote
It should be added.
