 another sst27sf512 + dual not working
ronald55555
Posted - 08/08/2007 :  09:47:16  Show Profile
I have a willem dual power, 0.97ja, sst27sf512(brand new), correct cable that came with the burner, I cant erase nor burn.
I've followed the following jumper settings.
DIP 3 5 7 8 9 on(as in the pic in the program)
VPP jumper on bottom 2(normal)
jumpers set for pcb3b
JP1 and JP2 set at normal for when i try to read or burn
extra jumper on JP1 for erase
The 2 jumpers set at 12V(normal)
The jumper under that at 5V
using ac adapter, with jumper set accordingly
I've tried 5 different chips bought from xenocron, so it's unlikely all of them are bad. I also followed the instruction on xenocron
http://www.xenocron.com/install/Willem-SST.htm
Here's what i've tried:
start with a fresh chip, erase(with jumper in), pops up the "set jumper for W......", i hit ok, bar goes to 100%, says erase ok on the bottom. But when i do a blank check, it fails. I tried to burn it anyway, I unplugged everything, close problem, remove one of the jumper from JP1, load bin, hit burn, bar goes to 100%, but it gives me an error on the bottom offset0x0000.
I've also tried burning a brand new chip without trying to erase first, same error.
After i try to erase, I hit read, and looked at the buffer and it was not all FF, even though it said erase ok. so the blank check is right. I also tried to read a brand new chip, and it was not empty neither.
I also tried the test H/W tab and mesured the voltage according to instructons i found on another site, dont remember the exact numbers, but they were fine.
Anyone has any clue what's wrong?
ronald55555
Posted - 08/08/2007 :  09:49:31  Show Profile
forgot to mention, the lights light up fine, VPP and Power on, program would come on when i try to read erase or burn.
I tried to burn at offset 8000
also tried 0.98d6 w/ the 2 jumpers set at pcb3.5, same problems.
Generated in 0.76 sec. Snitz Forums 2000
