 Whats wrong with ic Winbond 25Q64FVSIG
joelz
Indonesia
Posted - 03/12/2017 :  00:53:25  Show Profile  Reply with Quote
Hi, I try to flash ic W25q64fsig with device w25q64fwsig on Gq-4x, i can read end i can backup,also i can erase but very fast. when i go to blank check is always warning like this," Device blank check failed at address:0x000010,Read=0x5A
i used this line
Name="W25Q64FWSIG",ID="EF6017",Class="W25X10",Category="SERIAL_EPROM",MFG="Winbond",Vcc="3.6V",CodeSize="8388608",Adapter="ADP-081, ADP-027 adapter";
Posted - 03/12/2017 :  07:34:38  Show Profile  Reply with Quote
Line should be:
Name="W25Q64FVSIG",ID="EF6017",Class="W25X10",Category="SERIAL_EPROM",MFG="Winbond",Vcc="3.6V",CodeSize="8388608",Adapter="ADP-081, ADP-027 adapter";
Can you ID the chip correctly?
joelz
Indonesia
Posted - 11/14/2017 :  05:15:23  Show Profile  Reply with Quote
Line should be:
Read..Oke
Erase.. so fast
blank check..Device blank check failed at address : 0x000010,read=0x5A.
when i click on ID button it's shown W25Q64CV
please Help
Posted - 11/17/2017 :  06:57:37  Show Profile  Reply with Quote
Originally posted by joelz
Line should be:
Read..Oke
Erase.. so fast
please Help
What do you mean "when i click on ID button it's shown W25Q64CV" ?
joelz
Indonesia
Posted - 12/07/2017 :  22:44:52  Show Profile  Reply with Quote
Line should be:
Read..Oke
Erase.. so fast
please Help
its regonize as W25Q64CV, when i click read it's says " id check failed ("EF4017").
Posted - 12/08/2017 :  04:10:30  Show Profile  Reply with Quote
Line should be:
Read..Oke
Erase.. so fast
please Help
You have a Chinese fake. The chip is simply relabeled.
Posted - 12/28/2017 :  06:30:35  Show Profile  Reply with Quote
Line should be:
Read..Oke
Erase.. so fast
please Help
www.univ-st-etienne.fr/salware/Bibliography_Salware/IC%20Counterfeiting/Article/Guin2013.pdf
www.utdallas.edu/~gxm112130/papers/pieee14.pdf
https://pdfserv.maximintegrated.com/en/an/TUT5458.pdf
www.aeri.com/counterfeit-electronic-component-detection/
https://atadiat.com/en/articles/e-introduction-counterfeit-ics-counterfeiting-detection-avoidance-methods/
CoraDias
Posted - 04/09/2018 :  08:34:00  Show Profile  Reply with Quote
Hi...I am a new user here.What I want to ask you is when you had the EEPROM chip out of the motherboard did you replace it with an IC socket? Anytime I remove a chip for service or repair, I always replace it with a IC socket, if it did not already originally have one. This prevents heat from damaging the IC chip and also prevents further damage from being done to the circuit board by adding and removing questionable parts. It also limits the amount of ESD damage.
https://www.7pcb.com/
Edited by - CoraDias on 05/02/2018 13:01:57
Posted - 04/09/2018 :  09:38:44  Show Profile  Reply with Quote
No, it may introduce more failure points and cause reliability problems unless you know you will need to change the chip often...
You can also work in-circuit or use proper soldering techniques and equipment.
Correct ESD precautions is good practice but those chips are not ESD sensitive and a socket provides no ESD protection...
Generated in 1.16 sec. Snitz Forums 2000
