 Atmel 89 adapter
daveg Posted - 12/11/2004 : 15:06:00
Just received my unit and am trying to use the
Atmel 89 adapter to program a AT90S2313. I cannot
find that adapter in the list of devices for the
AT90S2313. Any help would be appreciated. Thanks.
daveg Posted - 12/16/2004 : 15:21:22
I think I found it. There is a "New Adapter" checkbox in
the AVR 8 bit RISC Lockbit/Fusebit Section that I turned on
and it appears that the AVR is now reading and writing.
Thanks.
daveg Posted - 12/16/2004 : 15:15:18
Thanks. I have put the Atmel 89 into the programmer,
but while in the program it does not give that adapter
as the one for the AT90S2313 IC. It shows a MCS-51 adapter
for this chip with 4 different IC sockets.
I have matched the Dip switch settings to the config that
appears for that adapter, but it does not seem to read and
write to the AT90S2313 AVR.
usb Posted - 12/13/2004 : 12:37:02
This chip should be supported by this adaptor.
All you need is set the jumper to 90S position and put the chip in the 20pin ZIF.
