 INTEL te28f160c3bd
tahir Posted - 06/03/2012 : 15:08:00
i have a gq4x with 8\16 bit adapter it says adp 077 on adapter with voltage jumper when i erase its erase vey quick 1% and says complete when i re read and check buffer it show data ive tried unlcock but still same im running off usb when writing it says on saying writing and noe movement on progress bar where am i going wrong thanks by the way the gq4x is awesome thanks also the gq4x fails id check all the time device not in libary but it is when i type it in thanks
tahir Posted - 06/04/2012 : 15:11:54
Thanks you it was wrong adapter ordered the the 16 bit 8 bit chips get I'd check pass and erase program verify properly thanks
ZLM Posted - 06/04/2012 : 14:43:59
Possible reason: 1. wrong adapter used. 2. bad chip 3. bad pin contacting.
Generated in 0.24 sec. Snitz Forums 2000
