 M27C1024 PLCC44 verify error
LUKAS08 Posted - 08/21/2019 : 00:54:33
Hello,
i write an eprom ST M27C1024 plcc44
the wirting process is ok, my problem is on the verify
the error is this:
Writing... Buffer
Elapsed time: 36.70 seconds.
Device write completed OK
ID check skipped
Verifying... Buffer
Verify Failed, Address=0x00050A, Device=0xFF, Buffer=0x1F
Verify Failed
if i read after writing if find lot of difference in the file
have you any idea?
thanks
anniel Posted - 08/21/2019 : 04:32:08
Originally posted by LUKAS08
Hello,
the error is this:
Writing... Buffer
ID check skipped
Verifying... Buffer
Verify Failed
have you any idea?
thanks
Try higher WriteVCC.
