 Write fail, adress=0x0001cc, buffer=0x3f device=0x
Dedou Posted - 09/26/2019 : 09:21:52
M27c4002
GQ-4X4 With Adp054
Blank check is ok
But when I write is false why
anniel Posted - 09/27/2019 : 10:26:23
Originally posted by Dedou
Thanks but how to change voltage and what voltage is necessary?
In the devices.txt you can tweak the voltages.
Dedou Posted - 09/27/2019 : 10:08:35
anniel Posted - 09/27/2019 : 02:44:50
I test all speed it's same'' write failed' '
Change the voltages.
Dedou Posted - 09/26/2019 : 23:42:11
anniel Posted - 09/26/2019 : 09:25:39
M27c4002
GQ-4X4 With Adp054
Blank check is ok
Try at lower speed.
