 D27C1001A & D27C2001D Codes
Necrosaro420 Posted - 01/25/2010 : 14:51:10
Anyone have the codes for the D27c1001a and d72c2001d codes to put in the config file? Thanks
VSDUAL Posted - 08/23/2016 : 17:10:49
Problem solved. If anyone else is trying to burn these chips, I had success using the GQ-4x4 and selecting MBM27C1001 as the device.
VSDUAL Posted - 08/21/2016 : 18:26:07
Same problem here. I have a few chips (NEC D27C1001A-12 Device ID 10D6) that will not write under:
D27C1001A
or
27C1001
Im using the newer device (GQ-4X4) and the newest software. I've been writing 2764's with no problems.
They write fail as soon as they start. Thankful for anyone who can help me get this done!
ZLM Posted - 12/05/2012 : 17:10:58
It seems you have some poor pin contact. check A8 pin of the chip.
Also, click on the ID and you should be able to get correct ID. Then do the write.
Carhartt Posted - 12/05/2012 : 03:27:21
To add, the EPROMs have been erased fully.
Carhartt Posted - 12/05/2012 : 03:26:05
Hi, did this every get fixed? I have a few NEC D27C1001A and my GQ-3X is incapable of writing to them, it doesn't even start. :(
Error message after failed write.
H/W Re: GQ-3X Re-1.50
USB Driver Re.2.0
Software Re. 6.11
<<D27C1001A>>
ID check skipped
Blank checking... Code
Elapsed time: 5.86 seconds.
Chip is blank
ID check skipped
Writing... Code
Elapsed time: 2.57 seconds.
Write failed, Address=0x000100, Buffer=0xFE Device=0xFF
Write failed
It does this on multiple chips, every time. Any help would be appreciated, thanks.
ZLM Posted - 02/09/2010 : 23:25:21
Can you send a sample chip for testing?
Necrosaro420 Posted - 02/09/2010 : 12:22:52
Oh yeah, ive done thousands with this, I tried them on 2 different programmers as well, PCB3 and Willem True USB. It says ID is: FFFF
ZLM Posted - 02/07/2010 : 22:21:07
Can yo get correct ID?
HAve you ever program any other EPROM on this programmer?
Necrosaro420 Posted - 02/07/2010 : 15:58:37
Heya, not sure if those are correct. Everytime I tried to burn I get an error message. This is after trying about 20 or so chips from different sources I have received and have been UV erased.
Write failed, Address=0x000000, Buffer=0x30 Device=0xFF
ZLM Posted - 01/25/2010 : 16:06:49
Name="D27C1001A",ID="XXXX",Class="27C010",Category="EPROM",MFG="Intel";
Name="D27C2001D",ID="XXXX",Class="27C020",Category="EPROM",MFG="Intel";
