 Need Information Flash Bios ACER AOD255
mrjepara Posted - 05/31/2012 : 21:29:37
I'm using QG-4X to flash bios Acer AOD255
IC code as shown in Figure
53.01 KB
Why not read the Program GQ USB Programmer
I've updated to version 6.14c
Please help me
Note : Device
EN257F80*SOIC8
EN257F80
mrjepara Posted - 06/01/2012 : 19:04:27
Originally posted by bis0n
try add this line to devices.txt (c:\program files\GQ USB Programmer)
Name="EN25F16",ID="1C3115",Class="W25X10",CodeSize="2097152",VCC="3.6V",Category="SERIAL_EPROM",MFG="Eon Silicon";
maybe line already exist with an ";" on first, in this case you can just remove ;
Other thing for mcumall, I have added an new device:
Name="A25L016M",ID="373015",Class="W25X10",CodeSize="2097152",VCC="3.6V",Category="SERIAL_EPROM",Adapter="SOIC8-DIP or ADP-081 adapter",MFG="AMIC",Platform="GQ-4X";
This working good...
Thanks a lot
This Working good......
bis0n Posted - 06/01/2012 : 01:31:59
And if you can't programm EN25F16 you can replace it by an AMIC 25L016.
After added line to devices.txt you need restart software.
Maybe you can replace by an SST 25VF016B too (not sure).
bis0n Posted - 06/01/2012 : 01:27:37
mrjepara Posted - 05/31/2012 : 23:52:12
try EN25F16
Code EN25F16 not found
ZLM Posted - 05/31/2012 : 22:13:40
try EN25F16
