 mx29L3211 SOP44 to DIP44 Programmer Adapter
juanmiglesias Posted - 10/16/2012 : 07:20:17
Hi i want to add support for 29L3211, already got the SOP44 to DIP44 adapter (universal eprom prog), also I own the 16 Bit EPROM 40/42 pin ZIF adapter that is need it for working with 16bit.
How can I add support for it? do i simple edit the devices.txt, can anyone help me with that? thanks.
link to adapter
www.ebay.com/itm/PSOP44-PSOP-SOP44-DIP44-Programmer-Adapter-socket-/120766350529?pt=LH_DefaultDomain_0&hash=item1c1e3c44c1" target="_blank">h p://www.ebay.com/itm/PSOP44-PSOP-SOP44-DIP44-Programmer-Adapter-socket-/120766350529?pt=LH_DefaultDomain_0&hash=item1c1e3c44c1
datasheet for 29L3211:
www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CCYQFjAA&url=http%3A%2F%2Fwww.datasheetcatalog.org%2Fdatasheet%2Fmacronix%2FMX29L3211TC-10.pdf&ei=93p9UPX9Gojk9ASa34DgAQ&usg=AFQjCNFuN0ymN51aaeXJTAPNPVTrye2LpA" target="_blank">h p://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CCYQFjAA&url=http%3A%2F%2Fwww.datasheetcatalog.org%2Fdatasheet%2Fmacronix%2FMX29L3211TC-10.pdf&ei=93p9UPX9Gojk9ASa34DgAQ&usg=AFQjCNFuN0ymN51aaeXJTAPNPVTrye2LpA
thanks in advance
topgeargames Posted - 01/05/2013 : 11:53:30
Awesome thank you!
ZLM Posted - 01/05/2013 : 11:01:58
Here is the software:
http://www.mcumall.com/download/TrueUSBWillem/USBPrgSetup6.18.exe
topgeargames Posted - 01/03/2013 : 10:39:21
ZLM? Ezosat? I want to be able to use these chips but until the software is released this adapter is a paperweight... Any updates?
topgeargames Posted - 12/31/2012 : 11:43:40
I received my PSOP44 adapter today for these M29L3211 chips, but the software still isnt on the website so I cannot use them. When will this software be available? It doesnt make sense to release an adapter without releasing the software for it...
juanmiglesias Posted - 12/22/2012 : 12:23:05
AWESOME! thanks!, I already backorder it!
ZLM Posted - 12/19/2012 : 20:17:16
You need download the 6.18 version software.
Check it back later in download page. It should be there later on.
topgeargames Posted - 12/19/2012 : 14:55:28
I cant see that revision. on the site all I can see is 6.17B, which doesnt have that chip in the device list. Is there a line of code that needs to be entered?
ZLM Posted - 12/13/2012 : 14:33:36
Now ADP-019 V4 is available and it supports MX29L3211 PSOP44 chips.
See:
http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=4561
The MX29L3211 is been added to software since Re6.18 release.
25.27 KB
