 GQ-4X Checksums change....
wolfievtec Posted - 03/03/2013 : 07:24:33
I'm trying to copy a AM27C020. It reads ok and I get the correct checksum but when I save it and try to put it on another chip it changes and gives me a bad burn. Any ideas?
Marin Posted - 03/07/2013 : 20:29:28
I think all AM27xxx in OTP( one time programmable).
I believe you can use AM29xxx witch can be read/write many times.
Also you need to empty chip firs before you want to write.
This maybe is your problem.
ZLM Posted - 03/06/2013 : 20:41:22
Before you clcik on write, the checksum must be a good checksum. Then the chip must complete the write and has to be verified with same checksum.
