 Trouble with the scripting system not saving a fil
RobMcRaf Posted - 05/16/2013 : 15:18:28
Is there a way to save a file within the scripting system? I see a LOAD FILE function, but not one that saves a .bin within the scripting system.
Got it! Works good so far. Am going through my pile of Ms Pac chips.
I noticed that the GQ-4X can run from a command prompt. I also noticed that there are dos commands for checking a .bin file against the MAME database.
Has anyone made a batch file to automate the steps.
1. I physically put the chip in (lets say I am doing a series of the same chip type to verify that the EPROM is good)
2. I invoke a batch file. It
- reads the chip with the correct settings
- saves the file to "c:\temp\test.bin", automatically overwriting if the old file is still there.
- invokes the MAME romident function with C:\temp\test.bin and outputs the results.
ZLM Posted - 05/22/2013 : 10:01:20
The latest software added this script command.
RobMcRaf Posted - 05/17/2013 : 15:53:32
I believe the script is unable to save data.
Well....I find that to be a gross omission in the software then.
ZLM Posted - 05/16/2013 : 22:16:25
