 24C128
Rich Posted - 08/07/2013 : 07:22:57
Hi
I have had a GQ-4X programmer for years now and its always been great, for some reason recently it has not read a couple of 24C128 eeproms, different PCBs but the same product. Is there a way of protecting the chip so the hex can not be read ?
Rich Posted - 08/10/2013 : 11:45:13
Doh.........having a moment, ignore the above post. Reads fine now
Rich Posted - 08/10/2013 : 08:44:16
Sorry, meant where / how do you slow the speed down?
ZLM Posted - 08/10/2013 : 07:09:30
slow down the speed only for reducing the chances on hardware compatibility problem. If this still does not solve the problem, then we need a detailed testing to find out the problem.
Rich Posted - 08/08/2013 : 23:13:43
100 % chip is fine, comes from a bootable control panel.
Why do you slow down the speed?
ZLM Posted - 08/08/2013 : 13:40:37
If you are sure the chips are good, then check the pin contacting and slowdown the speed.
Rich Posted - 08/08/2013 : 09:13:03
Just to add the exact number of the chip is.
24C128LI (CSI)
