 pic 16F627 is it no-longer supported?
Sarah_B Posted - 01/09/2016 : 01:42:48
Hi. I have a CQ-4X with the latest download or the softwre for it.
I can't find PIC 16F627 on the list any more. 16F627A and the 16F628/A
are there... I have tried using the 16F627A to program the device but it gives the "ID check failed.("2907A0")" etc..
Here's a listing of cut/pasted from the programmer... Any ideas?
I have a good stock of these and they are ok with the smaller routines.
Please check device type, chip's orientation and pin contact.
Some OEM chips may have compatible chip ID
Continue?
Yes
ID check skipped
Writing... Buffer
Elapsed time: 8.74 seconds.
Device write completed OK
Continue?
Yes
ID check skipped
Writing... Data
Elapsed time: 0.00 seconds.
Continue?
Yes
ID check skipped
Writing... User ID
Continue?
Yes
ID check skipped
Verifying... Buffer
Verify Failed, Address=0x000000, Device=0x3F, Buffer=0x16
Verify Failed
Elapsed time: 38.58 seconds.
Not initialized
H/W Re: -(SW Re. 6.38)
USB Driver Re.2.0
Software Re. 6.38
Many Thanks
SB
Sarah_B Posted - 01/15/2016 : 01:47:54
AAaah... that line was commented-out... I wonder why?
I'll check now to see if it's all working as it should..
Many thanks ZLM
Sarah
ZLM Posted - 01/12/2016 : 17:04:47
PIC16F627 is difference to PIC16F627A.
Try to add following line:
Name="PIC16F627",ID="2907A0",Class="PIC16F628A",Category="MCU",MFG="Microchip",ENDPRG_COMMAND="",BEGERASECHIP_COMMAND="8",DeviceFile="PIC16F627.dev";
