 AM29F200BB using GQ4X and new adaptor
Yaser Jafar Posted - 05/29/2016 : 18:35:02
I set it for AM29 and 5V, then I read, and I get all FFs.
Any idea?
stevocz Posted - 05/30/2016 : 22:17:54
yes, it can erase but not all data (only data where pin has correct connection).
Do you have right orientation (pin1 of chip to pin1 of adapter?)
Try a little bend the pins. Chip ID must be correctly readed.
Yaser Jafar Posted - 05/30/2016 : 17:34:26
Yes from a working Transmission Control Unit from BMW.
Would the programmer erase the code in the unit if no contact?
anniel Posted - 05/30/2016 : 16:09:57
Bad contact or bad chip. Is the chip from a working unit?
Yaser Jafar Posted - 05/30/2016 : 16:01:48
No, chip ID not read correctly. FFFF ID
stevocz Posted - 05/30/2016 : 04:35:28
you chip/adapter has wrong orientation or chip has bad connection between pins and adapter.
chip ID is read correct?
