 Disable verify during write?
mhdev Posted - 06/12/2016 : 00:27:23
Is it possible to disable verify during write? I'm trying to write M27C160 chips. They pass the blank check, but writing fails on the first byte saying the device=00. But if I then do a read afterward it shows the byte has the correct value, not zero. It seems like there is something wrong with the verify during write and if I could disable it then it may write the correct data.
ZLM Posted - 06/17/2016 : 21:14:01
No. There are something wrong and must be fixed.
Check your chip contacting. Also, do a voltage self diagnostic on programmer.
