 Device support request 25Q128A
83Air Posted - 08/29/2016 : 03:04:33
requesting support for 25Q128A-13eco tsop8
pdf:
h**p://ece-research.unm.edu/pollard/classes/595/n25q_128mb_1_8v_65nm.pdf
thank you
ZLM Posted - 09/11/2016 : 23:02:51
Try those lines:
Name="N25Q128A*SOIC8",ID="20BB18",Class="W25X10",Category="SERIAL_EPROM",MFG="Micron",Vcc="5V",CodeSize="16777216",Adapter="ADP-081+ADP-099 adapter",Message="Make sure the ADP-099 is used. The programmer will supply 5V voltage. Without ADP-099, the chip maybe damaged.";
Name="N25Q128A*SOIC16",ID="20BB18",Class="W25X10",Category="SERIAL_EPROM",MFG="Micron",Vcc="5V",CodeSize="16777216",Adapter="ADP-098+ADP-099 adapter",Message="Make sure the ADP-099 is used. The programmer will supply 5V voltage. Without ADP-099, the chip maybe damaged.";
