 Can't find devices.txt
gumi Posted - 01/03/2018 : 23:21:05
I'm having problems writing 27C256 EPROMs. I've read on this forum that I might need to change the device.txt file to match the device's data sheet. However, I cannot find the .txt file on my system. The programmer's documentation says "It is located in the application's directory." I do not see it there and I can't find the file when I search my entire system. Please help me find this file.
GQ-4x4
Software v7.15
Windows 7
Thanks.
anniel Posted - 01/04/2018 : 15:16:06
Originally posted by gumi
I found the file. Thank you very much!
You're welcome!
gumi Posted - 01/04/2018 : 08:50:59
anniel Posted - 01/04/2018 : 07:59:53
GQ-4x4
Software v7.15
Windows 7
Thanks.
In the USBProg software select "Device" in the menu then "User Folder" and the "devices.txt" should be there.
