 Can't program 16F628A
dburniston
Posted - 01/15/2008 :  18:51:35  Show Profile
I have the enhanced JDM programmer and I'm having trouble programming the 16F628A. I've successfully programmed a 16F877A and a 12F675, so I know the programmer is ok.
PicPgm finds the programmer and identifies the PIC as a 16F628A. When I try to program, it says it works, but verify fails. Reading the chip shows all 0's. I can erase and if reverts back to 3FF.
I've tried PicPgm, WinPic800 and IcProg with similar results.
Anyone have any suggestions?
Posted - 01/19/2008 :  01:11:02  Show Profile
Check the code protection bit. It seems that bit been enabled.
dburniston
Posted - 01/24/2008 :  16:29:14  Show Profile
Thank you!
Yes, the code protect was set in the sample hex file I downloaded to test. The program I was using didn['t make it clear until I checked with another.
I turned off code protect and it is working fine now.
