 GQ-4X programmer not working ??
benaknoun
Spain
Posted - 02/18/2011 :  04:23:14  Show Profile
Hi, i bought this programmer long time ago, i was using it on my 2 machines, XP and Vista, was working fine.
I havent used it for about a year, since then i bought a new PC but it has Windows 7, i am now trying to install the driver and software but it wont do it, ???
Is this programmer compatible with windows 7 ?
Can someone help please?
Bad_Ad84
Posted - 02/18/2011 :  04:41:02  Show Profile
works fine on windows 7, try downloading the latest driver from the download section?
benaknoun
Spain
Posted - 02/18/2011 :  04:54:44  Show Profile
Hi, yes i did try that from download.mcumall.com but it doesn't work !
i tried the programmer in my XP laptop, works fine
Any ideas ?
benaknoun
Spain
Posted - 02/18/2011 :  05:04:56  Show Profile
its coming up with this:
Error 1303. the installer has insufficient privileges to access this directory: C:Program files (X86)/ GQ USB Programmer. the installation cannot continue.Log On as an administrator or contact your system administrator.
The thing is, this is my PC and i am logged in as administrator and i never had issues installing software, just this time!
Any ideas please?
Bad_Ad84
Posted - 02/18/2011 :  09:49:51  Show Profile
right click the file you downloaded from mcumall and goto run as administrator
failing that, goto properties and then compatibility and tick run as admin
benaknoun
Spain
Posted - 02/18/2011 :  11:06:54  Show Profile
Hi, thanks very much for your help, i did the second option ( compatibility ) and it worked, it let me install software.
But when i connect the programmer, i get a pop up on the bottom right corner, new device found...installing driver software... and then it says: driver not found with a red cross !!!
I havent installed the USB driver from the disc, i am lost cause i get this when i click on: USBdriverV2.0.1_32_64bit, i get:
amd64 file folder
X86 file folder
GQwin64 setup information
Readme text document
which one is it to install USB driver ????
Thanks again
Bad_Ad84
Posted - 02/19/2011 :  03:30:31  Show Profile
I assume you are using 64bit windows, based on the "program files (x86) folder.
You need to copy all those files into a folder on your desktop called "drivers"
When you connect the programmer, in device manager right click and goto update drivers. then point it to the drivers folder yabove. this should install the drivers for you.
Edited by - Bad_Ad84 on 02/19/2011 03:34:14
benaknoun
Spain
Posted - 02/19/2011 :  16:12:40  Show Profile
Hi, yes i am using windows 7 64 Bit.
it's seems sorted now, i went to device manager, inserted the software disc that came with the programmer and installed drivers from there.
It works so far.
Thanks very much for your help, Top Man!
